Difference between smoke sensors FGSD002 and FGSS001?
Freebird
Hello!
As I could not find any previous thread about it:
What are the differences/modifications between the older smoke sensor FGSS-001 and the newer one FGSD-002?
Thank you so much!
I'm sure somebody will correct me if I'm wrong but I believe the difference is that the 002 is Z-Wave plus and is battery powered only where as the 001 was battery / mains powered and normal Z-Wave.
If, i'm not mistaken, then older one is not complaint wiht EN 14604:2005
