Fibaro Docs change variable
Im trying to use fibaro docs for the first time but i need a push in the right direction
I want to change the global variable "kWh" but i must do something wrong.
What do i post in the "Body" field
7 answers to this question
Hi @sonnyboy
perhaps this is a stupid question but are you trying to update the value stored in the global variable and change the name of the global variable itself ?
-f
    @AutoFrank
    Its the value im trying to update.
    @sonnyboy
    Thanks, I've never used the docs to update a variable
    Have you tried the lua approach
    I took a look at the docs and I can seem to get the parameters that relate to a global variable
    it looks like the id can be the variable name but when I try a PUT it fails
    which is a bit unexpected.
    To be honest I've never used this approach so I don't know if it works
    perhaps some other forum users have more experience in this space
    .. sorry :|
    Thanks for tryining :)
    i got the same result as you.
    With lua it works but i want to do it with the API, i got my old 1-wire system with the kWh per day and now i want that system to update the global, and 08:00 every day HC:2 sends a push or notifikation with the value stored in the global .
    Edited by sonnyboy
    With lua it works but i want to do it with the API, i got my old 1-wire system with the kWh per day and now i want that system to update the global, and 08:00 every day it sends a push or notifikation with that value.
    @sonnyboy
    definitely new to me but If it was me I'd work from the RESTAPI documentation and not docs
    might be worth a look...
    Hi @sonnyboy and @AutoFrank,
    If you want to change global variable value using FGHC REST API then in body you need to enter this line:
    @Sankotronic
    Many thanks :)
    @Sankotronic or anybody else
    Do you know how the complete url look like?
    This doesent work  http://192.168.88.148:80/api/globalVariables/kWh{"value":"7"}
    My "7" will change to "$1" when this is figured out
    Edit: Forget this i will do a Json readout intstead and update the variable from that VD.
    Edited by sonnyboy
