I am facing problems regarding wakeup interval and device changing parameters while working with homeseer.
Snapshot has been attached. If anyone other is facing same problem or has any solution please reply.
Snapshot has been added.
Thanks.
The device does not wake up automatically. It's in the manual. Why would you want to have it wake up at regular intervals? If it is because you want to set up parameters, please use manual wake up.
    I am trying to set wake up interval as you can see in the snapshot but after clicking on "set" when i reopen it it remains same as previous( not changes).
    My Major issue is "Device changing parameters" because I want to control dimming of my Fibaro Dimmer. And FOR DIMMING APPLICATIONS WE FIRST HAVE TO CHANGE PARAMETERS (ACCORDING TO THE MANUAL).
    But its not working.
    The device does not support setting the wake up interval.  Try 0 (instead of 6). The device does not support automatic wake up. It doesn't need automatic wake up. You will see a setting called "wake up" but it is not used. If you try to set a value, other than zero, it will probably go back to zero. Technically speaking "wake up" is not a parameter. Parameters and "wake up" are a totally separate and unrelated concepts.
    Setting parameters is not any different from other battery operated devices... Set parameter, wake up device, refresh information.
    Did you wake up the device manually after setting the parameter, then refresh the information in homeseer? That's how it works with other controllers. I own a Fibaro keyfob and a Fibaro HomeCenter, but unfortunately no "Homeseer" hardware or software.
    Off topic: please don't shout (use "all caps") - I hate that... I'm just trying to help... I wasn't shouting either...
