Devices with unticked "Show measurement of energy consumption"
I have a Aeon Labs clamp Energy Monitor that is connected to my solar panels supply. I have unticked the "Show measurement of energy consumption" in this device and all other Slave devices connected to this Master device.
With the unticked show measurements the Meter does not appear in the Power Metering Dashboard, but the Power values from this Energy Monitor are added to the Total shown on the Dashboard bar at the top.
Is this the correct behaviour I should expect to see when I untick the "Show measurement of energy consumption"?
I would expect the Values from the unticked devices to be ignored and not contribute the Dashboard value.
9 answers to this question
That is obvious bug that needs to be addressed and sorted out. Here is my situation:
I have only one meter with turned on consumption measurement, everything else is turned off and still is not same.
Edited by Sankotronic
Attachment quota filled up / deleting older stuff sorry :-(
" to "
Temat został przeniesiony z "
" do "
Can you tell me what exact devices both of you have?
    Aeon Labs clamp Energy Monitor the older version, not the new 5Gen
    I reported the issue. I will add the models of your devices to the report.
    Better description of the product
    This problem was posted and still not solved here:
    I have Aeotec HEM DSB28-ZWEU Second edition with one clamp , version 1.19 with template version 317
    All devices that measures power same as second set of HEM I unticked Show energy consumption measurements, so only first set of the HEM is ticked and still have discrepancy.
    Bug still not fixed in FIbaro 4.140.
