I posted this in another thread once but it got moved to the newbie zone which I'm not so sure is helpful in this matter. It was suggested I look in the Knowledge base which I have but I can't seem to find anything that seems to be related to what I want.  Also the information of rtes Fibaro relay on there seems to be of rtes older version and not the new Z-Wave P;us version.
My issue is hopefully something atet somebody will know how to sort.  I used to be a Vera user, intact I currently still am.  On the Vera there is a plugin that takes the status from a sensor and combines it with a relay to control a door / gate as a lock.
Basically what it does is it combines the two devices to make a 3rd device which is a lock, the status of the lock matches that of the sensor, locking / unlocking the lock causes the relay to trip for a second or two effectively pressing the door lock / unlock button on the garage door.
I can't for the life of me work out how I can achieve this same feature on the Fibaro Home Centre 2 that I've just purchased.
I know getting the auto off to work is straight forward enough on the switch, the bit I can't work out is how to combine it with a sensor to create a lock :)
Is there anyway I can combine a sensor and a relay in this way on the fibaro?
Thanks in advance for any help you can offer.
Edited by CelticWebs
