How to use a VD in a scene on HCL?
So I've finally managed to set up a simple Virtual Device to control my Sharp TV via IP control. I have a VD with two buttons (On and Off).
I am trying to use this VD in a scene on my HCL but I can't work out how to do this as it doesn't appear as a device to be able to be selected when setting up a scene. All info I've found seems to refer to LUA code, which I obviously don't have on the HCL. Am I missing something obvious?
Thanks.
5 answers to this question
Hi
Buttom11,21,31 are buttons on the VD
Edited by hTiger1
    Thanks for your response @hTiger1  but I don't seem to have the same options as you have. I have set up a VD and it works fine. However, in the scene dialogue, I don't see the Virtual Device option that you see (please see below). I am running the latest firmware but I don't know if I am missing something obvious!
    Hi
    What you show on screenshot seems to be criteria.
    It is only after "Then" that the virtual device menu appears.
    Så=Then
    @hTiger1 - Thank you very much - I am an idiot and did not realise it was that easy!
    1 hour ago, muppetman74 said:
    @ hTiger1  - Mange tak - jeg er en idiot, og var ikke klar over det var så let!
    Hi
    Glad to help. :)
