Considering the more frequent 503 freeze errors which requires manually restarting the HC unit I wonder If it would be a good solution for Fibaro to implement a kind of cloud monitoring system and in case that our HC gateways for any reasons are not available anymore to receive a push or email notification about this.
Currently if the HC for any reasons freeze and needs restart we are not made aware of it until actually have a need to make use of the system.
At least if you are away of home and receive a notification from the Fibaro Cloud that your HC gateway is offline you can prepare accordingly to jump the fence because the gates are not opening :)
A push-notification message with restart option would be even greater!
User shall have possibility to enable / disable this notification function and also to set a desired check interval (every 1min / 10 min / 100 min....)
    Do others have a different solution to be notified when HC freeze to avoid being "surprised" when back at home and no automation works ...?
    Fibaro cloud with interval check monitoring and with auto-restart should be a good solution, don't you think so?
    Pff
    Thinking out load: cheap android tablet running tasker that is running a scene or pressing a vd button that does an action on tasker on the tablet.
    if the action fails you get a notification.. (using autoapps to get the actions on the tablet)
