All devices gone after update
Hi guys,
After doing the latest update, 4.120, all my devies and other information is gone.
I am able to login onto my HC2 but there is nothing in any of the directories.
Does anyone have an idea of what is wrong?
Kind regards!
Step 1, empty the web browser cache, refresh the browser .
step 2 restore backup if step 1 not working
    Thank you for your answer!
    Tried both options.
    Tried several browsers with and without empty cache, this did not solve the problem.
    Tried to recover HC2, also did not do anything... (it did not recover, it just keeps flashing the blue "tool" led, all other leds are on.
    Any other suggestions?
    It seems like I cannot login as admin anymore.....
    Is there a way to reset the admin account?
    Hi @DeNnZ
    I have some issues with a backup and I documented the recovery process
    There may be some useful information there
    _f
    Quote
    Wery important information for us.
    Only the three most right leds should lit.
    Try this:
    Shut down your HC2
    Remove the recovery stick
    Start your HC2
    Does it start up now?
    If so, contact support.
    Edit
    If not, contact support
    Edit
    Admin is no more admin
    Use your mail-address you used in the wizard
    Edited by RH_Dreambox
    I just got it to get into recoverymode.... Recovering now but it seem to be stuck at 40% in step 1 (checking revovery files)
    I'll give it some time to finish otherwise ill let you know..
    Okay, recovery is finished, but nothing happened....
    Still same old situation..
    Started without recovery usb installed...
    When the usb is installed, starting takes VERY long..
    I still cannot login as admin, it says my password is incorrect....
    So just to be clear:
    * Starting HC2 WITHOUT recovery USB works..
    *Starting HC2 WITH recovery USB works reaaallly slow, the last LED keeps blinking for a long time but eventually the HC2 will start
    *I cannot login with admin account (I dont see the admin account in the user list?)
    Oh, and some info from the recovery options under settings:
    Recovery memory:Ok
    Checksum status:Not Available
    Information not available (unexpected error)
    @DeNnZ, what version did it recover to ?
    @AutoFrank Still on 4.120...
    @DeNnZ
    so the recovery didn't work at all ?
    No clue, like I said in an earlier post, it seemed to be stuck at 40% in step 1 (checking revovery files).
    30 minutes later I logged back in and it showed the regular login page and seemed like nothing had changed..
    @DeNnZ
    Thats very weird .. fibaro support I think :-(
    I think I could solve the problem by logging in to it with the admin account, but that aint working... it says the password is incorrect..
    @DeNnZ
    I used admin/admin but before that didnt work for me so I had to launch the wizard and create the fibaro id (email login)
    see if you can find some way to launch teh wizard and login that way...
    EDIT
    My restore is not looking good, may need to go again..
    Edited by AutoFrank
    I think you can start the wizard like this: http://<<IP OF YOUR HC2>>/fibaro/en/wizard/
    Jim
    Edited by jimicr
    Typo
    YEAH, I got in!
    I managed to remember my email and the password needed for the login!
    Thanks guys, for pointing me in the right direction!
    YEAH, I got in!
    @DeNnZ
    @jimicr
    great stuff - let us know how you get on
    I'm on recovery #2
    1 minute ago, AutoFrank said:
    @DeNnZ
    @jimicr
    I'm on recovery #2
    Oh man good luck.. what went wrong the firs time :(
    well, I did not use the email to login as admin...
    I was trying admin/admin but ofcourse that did not work anymore,....
    I forgot I had to use my email to login :-)
    Anyway, I have no clue why my recovery did not work...
    Everything is still there, my scenes and all my devices...
    Edited by DeNnZ
    @jimicr, didn't restart after the restore, just the spinning blue balls :-(
