FGS-213 local switch control problem
I have 2 FGS-213 relay modules , buy from different stores , but the problem - the same . Offen , if i try switch on light by local rocker switch (with fixed on and off positions) i have no any reaction , light remain switched off . But , if i try another 1 or 2 attempt on-off switch light , module start working and light is turned on . Immedeately after this , if try switch off or swich on - all worked fine without delays. All settings from controller are "default"  . Looks like module go to deep sleep state and wake up with problems.
Local rocker switch connected to S1 terminal. S2 is free.
No any OTA available firmware update in FGS-213 relay settings.
Any ideas?
