Hlloyd 0
Hi
i would like to be able to override a sensor triggered scene with a wall switch
Does the home centre 2 no the difference between a wall switch command and a scene triggered command
Would i be able to wright an off scene for my sensor triggered light that can be overridden by the wall switch so that the light stays on until it is manually turned off
At the moment i am using this scene to turn off the light but would like to use the wall switch to keep the light from turning off when there is no movement
