Aeotec multisensor 6 with HCL, parameter problem
I just bought an Aeotec Multisensor 6. I tried to set parameter 41 to generate a temperature report, but I see the attached bug. Everytime Im trying to set 1C or any other value after the save i got random big number for parameter 41.
Also its pretty strange that the motion sensor does not react too
Did somebody experienced the same, or any idea how to solve it?
9 answers to this question
Yes, update sensor to firmwire 1.8...
Hi @kalmanv
No, you don't have to update sensor.
After setting this parameter it is set properly, this is just bug on the interface part. You can check if parameter is set correctly by clicking on default button. You will see that it will show actual settings without really setting it to default value, that is if you click Default button only once.
FYI its almost impossible to update the firmware of these sensors without an AEOTEC USB thingy... unless @Sankotronic knows any tricks?
oh and more to the point, you dont need to update the firmware... it still works, its just a bug but works as designed.. tip with these sensors, use the USB cable and not batteries
Hi @amurray85,
You really need to read more carefully other people posts before writing one. Here I will quote myself again with bigger letters:
As you can see I don't have any tricks regarding firmware update for Aeotec ms6, but I do have trick how to correct that GUI problem and check settings! :-P
lol @Sankotronic buddy i was agreeing with you.. read what i wrote a little more carefully
i was curious if you had updated the firmware with any tricks... i agreed with you that he didn't need to update. i was making a statement around the update process itself
Edited by amurray85
Well, then I should learn better english, sorry:-) It really sounded like I was the one proposing firmware update :-P Thanks for slapping me back! I deserve it! :-)
It is possible to do firmware upgrade, but if I remember correctly it doesn't really help with this GUI problem.
For now I have only one ms6 and it seems to be good choice if you need humidity sensor too.
all good.. we are here to help each other :)
    Thank for the responses, sensor is getting good now. I have one problem left, if the motion sensor is breached fibaro is saying 15mins ago..but it was breached a few second ago.
    I have also fibaro sensors too i dont have this kind of problem with them.
    Any suggestions?
    Any suggestions?
    Maybe too late for you, but it could be useful to others: I obtained exact time setting the ntp server to my local time server - from pool.ntp.org to it.pool.ntp.org
