Flash226 3
Heating works with scenes and variables. Sometimes you need to turn off the heating in some rooms. For convenience, I created a virtual device in which you can change the value of variables. Below is the LUA code for one of the buttons that turns off the heating in the basement (Changes the variable Heat_basement from auto to manual).
/monthly_2017_05/888.png.2f936854d39e95cb52cd012cb71abe8b.png" />Variables change successfully. But I need to turn off the devices with ID 74 to 75 when changing the variable to "manual". As I understand, i need to insert the code
I tried to insert it in different places but it does not work.
Prompt please where exactly it is necessary to insert the code of deenergizing of devices. Maybe I need to add something to the LUA code?
Edited by Flash2263 answers to this question
