[SOLVED] [API] POST: Scene Action Start with parameters
I'm trying to start a scene from HA-Bridge using the Scene Action API using a POST HTTP call.  It works fine if there are no parameters being passed in the message body, but as soon as I add a parameter, then it returns HTTP 405 (Method not allowed).  So I tried calling the API from SoapUI and I get a 405 returned there also.  HOWEVER if I call the API from a browser using the /docs Try It! helper (
), then it works fine.
So I trapped the message being sent from the browser (the one that is working), and I get:
The message that I'm sending from SoapUI is:
I've tried modifying the headers in SoapUI so that they all match the browser values, and I still get the error.
Anyone got any ideas as to why it's not working?
Thanks,
Dave
Edited by Dave Harrison
Solved
    This is now working :D.  I noticed that the connection would work correctly in SoapUI when 'Preemptive Authentication' was turned on (not at all sure why :?).  Therefore, realising that it was authentication related, I changed the request in HA-Bridge to provide the authentication via the HTTP headers, rather than via the URL.
    So for anyone else looking to do the same, this is how it's configured in HA-Bridge:
    Where <nn> is the scene number, eg:
    And the value in the HTTP Header after the word 'Basic' is your Fibaro user id and password separated by a colon, and encoded in Base64.  Use a site, such as
     to do this encoding for you.  So for example:
    becomes:
    In the scene, you can read the parameters using the fibaro:args() function, eg:
    Dave
    Full solution now posted to Crowd's Solutions/Other Solutions:
