1. When You (Fibaro) will add the possibility to use the all TLD domains. Many persons use email in domain like *.name, *.home, *.family, *.online.
From more that 5 years this TLD domains is not only on ICANN paper but they live!!!!
Is not very complicated change the filter in script for this!!!
2. For communication between Fibaro support and HC you use SSL for protect... I things root access from be see by users. But You not protect users access on port 80 (direct, NAT or by passed by fibaro cloud to HC), any sniffer and not only the lamps in home is accessible for hackers. What is more important. Your protection against user or protect user resources?
3. When You add patch for LUA (internal support case number  SFS-340) ( [ fatal] LUA error: /usr/share/lua/5.2/json/decode/util.lua:35: unexpected character @ character: 1 0:1 [<] line:)
I asked many times for the date for this  important functionality and patch, and received many answers with many dates or promise that is will be included in the next version !!!,,, and next version changed to present, present changed to previous, next for next changed to present and we wait and wait and wait.
Please give us the one but true date of implementation for patch and possibility to choose between HTTP or HTTPS and use the any email address not only from old type of domains.
" to "
Temat został przeniesiony z "
" do "
