Not connectable - looks dead
Not accessible through network.  Only two LEDS from right are on. I have power down and up multiple times.  Has anyone had the similar issues?
5 answers to this question
Hi @romraj couple of things, have you tried a hard reset. Secondly if you do the reset does it hang on the last illuminated LED. my first Homecentre2 locked up after I updated it. I couldnt get the web service to come back up and after hard resetting it it would flash the LEDS from Left to Right one at a time until the last LED was flashing but all the others were solid. But it never came back and was essentially Bricked. You can open the covers and access the VGA port and hook a monitor up and it may give you a fault code. Never found out what caused mine to fail, luckily my supplier replace it.
    Hi @Dugbi, Thanks for your quick reply.  How do perform the hard reset?
    7 hours ago, Dugbi said:
    ...until the last LED was flashing but all the others were solid. But it never came back and was essentially Bricked. You can open the covers and access the VGA port and hook a monitor up and it may give you a fault code. Never found out what caused mine to fail, luckily my supplier replace it.
    The same for me now on HC2. Only one LED flashing (on the left side) all other LEDs is solid. Monitor connection dont help - its dark. Any solutions here?
    Same issue here, service led (on te left side) keeps flashing. Already tried every possible way to reset the HC2 but without any results. I don't know if I should send it back to fibaro or I should replace it with another competitive brand...
    An answer from fibaro would be nice.
    Try to start your HC2 without mounted Recovery Stick. If this works, the boot files on the Recovery stick can be defective.
    Or have you tried to make a total Recovery?
