I have an LED by the front door that i want to turn on if any light is on.
If a make a block scene, with: "device group" IS "Not equal" TO "ON" THEN LED == OFF it works as I would expect (turn off the LED/warning light when no lights are on)
The same is not the case with the opposite block scene, if I create the same scene, in reverse, it doesn't trigger the scene if any of the lights turn on.
I've tried creating the second scene with "Group" == ON THEN LED = ON and this only triggers  if every light is turned on.
If i create an IF Light1 on OR light2 on OR light3 on... etc. scene it works as expected, but this is tiresome and needs constant adjustments. And, also is really slow and i'm guessing putting some strain on the HCL CPU.
What am i missing? I wan't the device group to register "any light on" not "all lights on"
Edited by lurendrejer
