Hello, i want the RGBW-Contoroller to set a specific color each time it is turned on - no matter witch color-setting or brightness it was turned off. I tried it with scenes, but the only value i get from the controller is get.value - and with this the colorsetting runs in a loop and is not changeable after switching on. I think the only way is to turn the controller in In/out mode - but i still want to use hold momentary-switch function to control the brightness.
Any ideas?
Configuration:
RBGW-Mode
momentary Switch
RGBW-Stripe
Edited by Radiohead
the way to set this up would be using the switch.
i use a toggle switch and i run a scene which is fixed to a certain colour every time it is switched 'on' ie when (value == '1')
if ( fibaro:getValue(ID,'value') == '1') then fibaro:call(ID, 'setColor','R','G','B','W') end
with momentary you would have to do some extra coding to determine whether you switching on/off as when you press and let go, it would see a value as '1' then '0' or turn off the strip lights by another method..
hope this helps
    Thank you for your idea, but this is not practicable for me. I have 5 momentary switches in a row to control this device and i sill want to use the dimming function by holding the button.
    let me know how you are using the 5 momentary switches?
    my assumption is IN1 to IN4 is connected to 4 of them?
    the 5th one to turn on/off??
    if so 5th momentary can be used as above...
    i wrote "in a row" so i mean 5 on port1. in this case i cant use switches.
