Problems With HC2
I realised i had problems to connect with my HC when i could not access it remotely. When I came home and tried to restart it all but the las diod were lit. The last one was flashing and nothing happens. What is wrong with it and what could I do? I have tried to restart it by holding the + button but it is still the same. It just sits there with the last diod flashing.
Sincerely
ukan
Switch off your HC2 and pull out the Recovery stick.
Try to start it again whitout the stick. If success,then there is problem with the Recovery stick.
    Tried that. It does not work. It does not matter if the stick is in place or not. Other tips? :-)
    Sincerely
    ukan
