Hello. I have problem with this plugin - Sony TV. I have added this plugin to my HCL. When I clicked Search (IP address blank) after 5sec I get "Unfortunately there are no results for device search".
My TV > sony kdl 48wd650baep , of course with LAN connection.
Somebody have similar problem?
Also I have added one WoL plugin (wake on lan) to PC and I have no problem when I click "search" - after 5sec I get IP and MAC of my PC, TV and others devices connected to my router.
Regards
4 answers to this question
Same Problem here … Any Updates? I also added the authorization code (i hope it's the one you have to set up in the tv's menu).
Thanks!
Few years past.
Did you manage to control your Bravia with Fibaro? I found solution for Home Center 2 but my is HCL
Hi Quite a few more years past!
Just bought a new xh90 sony and downloaded the addon. Still the same as the original post.
Does anybody know how to get this working, tried adding in the IP address and setting the authorization code to 0000 and the pre shared key on the tv to 0000 but no idea what I`m doing?#
Hi. This plugin is long dead. Just download one of VDs from the marketplace. Works flawlessly with the new Bravias.
