robmac 173
Hi all and @Fibaro,
I have been running the Alexa skill for a number of weeks and mostly it works with no issue.
I have noticed that occasionally that while Alexa says OK when turning off the devices it looks like the wrong command is sent to HC2. I see transferred OK reported on the device but the device does not change state.
All of the devices that are causing the issues are Fibaro switch2 devices that I had tested with the scene events functionality. I set Parameter 28 so that the functionality was no longer active and this appears to have fixed the issue.
Please can somebody else test this to confirm that there is a bug in the skill, HC2 or the switch2 firmware that when parameter 28 is set prevents the Alexa skill turning off the switch2 device.
cheers,
Robert
