HomeSystem.sk 69
I need to solve one situation, locking alarm by Widget (or scene activation by the button). But I need it as well to push the notification, if any of the windows are opened (and if, then which) when the scene run. I know this is simply done by opening the app and locking the alarm in the Alarm section, but for the easy of use I need to have this done by widget.
So I have this scene, it was working for some time now but recently I am getting more and more notifications about opened windows even thought the windows are closed. This started to happen at 4.120.
Here is the scene. You can probably see I am self thought
In this scene I first armed the window sensors and after that I checked the status (armed or disarmed) as if I did it by checking the window status first (by open/closed) then if the result was false, then the other sensors would not arm. This my way I see which sensors did not armed. Probably there is a beter way, but as I said, basics
I have code for each sensor there as each notification is different, so there is info about which window is opened.
At the end, the motion sensors get locked (after 20 seconds, when they get out of blind time). I know this can be done by setting the sensors, but I have another scene for sleeping when I need different timing.
Ok so as I said, the scene used to work as I needed it, but recently more and more notifications are comming after trigering it. I had first just push about one sensor not armed (even thought the window was locked) and now I get basically every sensor not armed.
I would really appreciate any help here, or maybe another way to do this, locking the alarm without opening the application with the feedback about windows status.
Thanks a lot
