Setting the ring colour on the Fibaro Wall Plug
In advanced settings on the wall plug it set the ring to be red when off and green when on, but only the ring on the icon in the GUI changes and not on the plug itself. Any suggestions to what I am doing wrong?
Probably this:
LED ring illumination may be turned off completely. To do so:
1) Insert the Plug in a socket,
2) Press and hold the B button for 2-5 seconds, till LED ring starts pulsing white,
3) Release the B button,
4) Press the B button briefly.
Plugs relay will not change its status.
After the LED ring has been turned off, it can be turned on by completing again the above procedure.
