SIP Intercom. Run scene after call.
Guest Roman
Hello Fibaro users.
Probably everyone knows HC2 has embedded Asterisk SIP server.
So different intercom panels could be connected to it.
Is there possibility to run scene when guest clicks call button on intercom?
Hi Roman.
I do not know about Asterisk embedded (FIBARO is BlackBox for us) but I can call to FIBARO Video Gate or make call to other users from embedded Android dialer and from raspberry pi via PJSIP
I'm playing with button + web cam (with mic) on raspeberry pi and yes, I can make calls from python on raspeberry to FIBARO VG.
PS: not sure about guest calls, I'm assigning number
 for RPI button
I'm very intererested in these kind of idea's..... Pls keep me updated!
Guest Roman
    Hi, thank you for this idea, really cool!
    But in my case I'm trying to find solution without a lot DIY.
    And it would be great to catch pressing call button from intercom like this:
    Also interested in this new plugin (provided on screenshot).
    Huhhhhh?????
    @Roman You have another list of fixes and changes for Beta 1.131......
    Guest Roman
    My page already looks the same as yours (
    Probably Fibaro had just removed it ...
    Too bad..... I just was gettin' hopeful.
    Thinking about to be using some day  my (too expensive) 2N Doorintercom in combination with my HC2's ;(
    only from release notes, for a reason, but not from the update itself.
    afaik this works only from custom plugin (as one can capture from what so ever from os and return results to custom actions in plugins).
    I was digging a bit with luci asterisk monitor in VD, but it was not working, lot of problems with socks, etc.
    I heared that they are planning to bring out the Fibaro intercom at the end of 2017....  And if my sources say so, I do believe them... I even made a reservation for at least one ;)
    Hi Roman. Some intercom panels have embedded function to send http-get request by events (as example, pushing the button on pannel). So it can be used as trigger for scenes in HC2 (through HC2 API).
    Guest Roman
    Thank you for reply! Could you share models with such feature?
    We have tested Beward intercom SIP panels
    They have enhancement in firmware "http-notifications" and it can be used for scene activation on Fibaro when intercom button is pressed
    Configuration example:
    Guest Roman
    Thank you!
    Спасибо, судя по описанию очень удачные устройства ;)
    • 1 year later...
    On 26.06.2017 at 13:14, Zodchij said:
    Мы протестировали SIP-панели внутренней связи Beward
    Они имеют улучшение в прошивке "http-уведомления" и могут быть использованы для активации сцены в Fibaro при нажатии кнопки внутренней связи.
    Пример конфигурации:
    Hello, I bought a Beward intercom. When entering the string "/api/sceneControl/?id=36&action=start" in the Network/notification and pressing the "test" button everything works. But what to write in the section - Alarm/call button/Http notification??
    Put in the "Request" string (as on screen above) only this:
    /api/sceneControl
    and for Alarm/Call button/HTTP notification (with checkbox marked) this one:
    id=36&action=start
    Edited by Vladimir_st
    hi,
    is that also works AKUVOX IT82 intercom panel too  ? they have own sip server and cloud servis.
    thanks
    On 17.04.2019 at 00:47, Zodchij said:
    Вставьте в строку «Запрос» (как на экране выше) только это:
    / API / sceneControl
    и для Тревоги / Кнопки вызова / HTTP-уведомления (с отмеченным флажком) этот:
    ID = 36 & действие = начало
    Did you not find a way to open the door through Fibaro?
    21 hours ago, malitan said:
    Привет,
    это также работает интерком панель AKUVOX IT82 тоже? у них есть собственный sip-сервер и облачный сервис.
    Спасибо
    You need "http-notifications" .
    Привет,
    Спасибо
    Yes, I have checked with Virtual device.
    Create new Virtual device, put IP address of your Beward pannel and port number 80 in configuration, add one button like on the screenshot (use correct Beward pannel credentials in the string).
    /monthly_2019_04/491190884_BewardRelay.png.a3fc50ad59822446c66d7f3949234a84.png" alt="491190884_BewardRelay.png.a3fc50ad59822446c66d7f3949234a84.png" />
    This command will control switch on Beward controller.
    Did as you say (entered your password, IP address, port). Why it is not working :( Please write the string in the browser.
