Hi
I'm trying to use a sip server intercom with my home centre 2 and like to know how i would config the sip server intercom with the fibaro voip panel
Is there a Port number the voip panel uses?
5 answers to this question
    I got the intercom to work with the voip panel.
    The intercom will call my phone i can answer and have video and two way audio.
    But I cant seem to get the voip panel to work remotely.
    If i turn my wifi off on my phone the voip panel will not register with error message registration failure
    I have even port forward my home centre 2 and tried to use my wan address but the voip panel just will not register
    I would also like to be able to unlock the door from my app is this possible?
    Please Help
    Hi @Hlloyd,
    Did you tried forward port 5060? I think, that is the one Fibaro is using for VoIP.
    Also, maybe VPN could be a sollution for this.
    Edited by jakub.jezek
    As far as I know, it is a local SIP server, hence the name intercom.
    In case you find a way to call devices away from local LAN, please do share.
    AS sip protocol is quiet a difficult thing for a router handle, I would go with setting up a vpn server within your network and when your out,always have a vpn connection open to your network at home.. With vpn you go straight though your firewall in a safe and secure way and the sip server thinks your still locally connected.
    @Hlloyd I am curious as to what intercom/videophone are you using? tx
