Hi
I have 3 shutters (Canopy)  which I control with a FGR-222 module
I want to  set to the canopies to a certain position depending on the wind
I have create several Lua Scenes to achieve this and is working fine
So far so good
But  now I  want to  disable the buttons for  5 minutes with lua code
There  is a setting ( checkbox)  in the template of the module to  disable the buttons
Is it possible  to  set it via lua code
Or is there another way to do  this.
Thanks for  you help  and idea's
 greets
Jos
" to "
Temat został przeniesiony z "
" do "
    Hi
    I saw this was moved to  the forum  modules
    It would have been better if  you had  a solution  for my request ... :-)
    Actually  it is the lua code what I need to disable the module , so for me it is more scene related as modules related
    Anyway
    I have seen a discussion about this command in LUA
    fibaro:call(578, "setEnabled","False")
    This is also a possibility , but I am not sure if this available for the FGR-222
    But even so better would be that  the buttons are disabled for  a certain time via a scene ( lua code )
    as disable the whole device will imply that also the scenes that  are programmed for  this device will  not work any more when the device is disabled , while disabling the switches will  still  allow the scenes to  be run
    Jos
