Timer and variable in scene as condition does not work
I have a scene that checks a variable ( 0 / 1 ) at 6:30 pm each weekday. If variable (VattnaEj)  = 0 scene should turn on device, if variable = 1 should do nothing.
My problem is that the device is turned on any and every time when the variable changes from 1 -> 0. I want this to happen only at 6:30pm AND if variable is 1.
Any help ??
LUA:
%% autostart
%% properties
%% weather
%% events
%% globals
VattnaEj
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "18:30")  and  tonumber(fibaro:getGlobalValue("VattnaEj")) == tonumber("0") )
then
    fibaro:call(51, "turnOn");
    fibaro:call(242, "sendDefinedPushNotification", "20");
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
 ( (currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7)  and  tonumber(fibaro:getGlobalValue("VattnaEj")) == tonumber("0") )
or
then
Remove VattnaEj from the header lines.
VattnaEj serves as a trigger that starts the scene each time the value changes.
    Tack !
