tft7000 0
Hello
I have a HC2 v4.130. I wanted to try to create a new virtual device with a simple lua script. However the script always fails with '[ERROR] 15:47:28: line 183: Assertion failed'.
The script currently only consists of the following lines:
If I remove the 'fibaro:countScenes' command, the script is working.
Is it possible, that virtual devices in v4.130 do not understand the fibaro:countScenes() command?
What can I do to fix it or to work around this issue?
Thanks.
Edited by tft70001 answer to this question
