Rostor 0
I'm trying to add a slave gateway to my Maste HC2.
The slave HCL is in another house with static ip, I nat the external port 9090 to internal HCL ip address port 80.
I can connect to the HCL with the browser to the 9090 port with no problem, but if I try to add the remote gateway to my HC2 with the port so ipaddress:9090 I receive the error "Connection error. Check Home Center network connection and try again"
The only way to make it work is natting the 80 port directly to HCL, but in any case the serial number of the HCL is not showed in the panel (see the screenshot).
I'm missing something about port ?
Thanks,
Renato
