Hi All,
Can someone tell me how or put me in to right direction on how to setup following time intervals scenario:
Device is single switch,  turns Water Circulation Pump.
Pump needs to work between 7am to 9pm every 15 minutes for 3 minutes.
Best Regards, @ Thank You in advance,
4 answers to this question
Hi Fully,
This should work for you.
    Hi RH,
    3 minutes interval is spot on, 15 minutes interval looks like algorithm not timing properly. It actually not considering actual start time.
    Instead of 15 minutes is around 12/13 minutes. I will see what happens tomorrow from the start to finish.
    Many Thanks!
    15 minutes its actual 12 due to 180 delay. All works fine. thanks again.
    I realized that you wanted a pump start every 15 minutes and that the pump would then circulate 3 minutes within these 15 minutes.
    Or would you like a pump start every 18 minutes (15 + 3 min, 15 min between pump start and pump stop)?
