I've got a problem with the Fibaro Relay switch 2x1,5kw. I would like to se it as an alternate switch in the lobby.
So when I arrive home I switch on the light near the entrance, after that I walk through the lobby and I would like to switch off the light on the other side.
How can I connect correctly the Fibaro relay switch for this task.
Andras
If I understand you right you will find the wiring diagrams here:
hope these help
Andy
