[SOLVED]Unable to connect to HC2 on Android app 1.15.0.1
I recently updated to the 1.15.0.1 app and cannot connect to my HC2 anymore.
There used to be an option to enter the IP of the HC2 but I cannot seem to find it.
The HC2 is not connected to the internet so I am not able to login via the Fibaro ID.
Best Regards
Edited by MrB
5 answers to this question
Hi @MrB,
and welcome to the forum.
You have to be in the same network with mobile data turned off. Then you shuld be able connect to your Home Center.
Edited by jakub.jezek
    Hello Jakub,
    Thank you for the reply.
    I am in the same network. I can ping the device and am able to access the WebGUI from the browser (both from my Android device) yet the app cannot find the HC2.
    I turned off mobile data but it made no difference.
    @MrB, can you check, if you mobile does turn first letter in username into capital one? maybe that is the issue.
    If not, then can you try to reinstall app?
    @jakub.jezek  Good point, but I've turned that (damn annoying) 'feature' off a log time ago :).
    I already had reinstalled the app several times but with no succes...
    However...  after some more reading I read some advice on clearing the app cache/data.  This solved the problem.
    Thanks for your input though!
    I knew it was a bug-ish kind of thingy !!! :-)
