[solved] Single Switch 2/Double Switch 2 Pairing with Vera Plus
Update after a bit more fiddling:
I've now paired the Double Switch 2 and Single Switch 2 to my Vera Plus gateway. Only after reading about Z-Wave secure and the need to put two devices really close together for key exchange I tried to put the switches right next to my Vera Plus gateway for pairing. That worked in the end.
Br, Magnus
______________________________________________________________________
I'm started relatively recently with home automation. I own a Vera Plus gateway, a couple of Fibaro Roller Shutter (2) modules and recently bought a Single Switch 2 and a Double Switch 2. And while all Roller Shutters paired successfully and without any glitches with the Vera Plus I cannot get neither the Single nor the Double Switch to pair. For users of the Vera Plus, I'm trying to add them as a Generic Z-Wave Device using either the (Press three times) S1 switch or the B-Button on the Single/Double Switch itself. Neither leads to any recognition within the Vera Plus.
Is somebody successfully using this combination and could guide me with the steps? Thank you!
Best regards,
Magnus
Edited by MagnusK
Found solution to my problem.
