ggoetz56 9
I can't believe that this is not discussed in the Forum, but I don't find scenes, vd's or any other soultions for opening a gate, door, garage etc. So maybe a link will do.
My quest with HC2 is to command a sliding gate (carport). If you believe in roller shutter 2 manual, it is the correct device for doing that. But this will control the motor its self.
Ich have a "hörman lineamatic P" which provides the wiring for a pushbutton switch for external control. This seems to me the much better way to connect HC2 with the motorized gate. I tested a double switch doing that, but im not absolutly convinced about my solution.
So maybe some one has posted his solution or knows any articles about that issue.
Thanks for any hints
Gerhard
6 answers to this question
