Alarm Sounder & Fibaro Button
Guest spazpeker
Couple of issues
With the Alarm Panel it is very easy to do things on the triggering of an alarm "from alarm start", however when the alarm has been disabled there is nothing to configure in the alarm panel "from alarm stop" .
I have a scene that when any sensor changes its status runs and if all sensors are disarmed it turns off the sounder, this works fine when entering the pin the alarm and sounder stop.
However when you set off the alarm with the panic button and disable the alarm it wont trigger the scene and turn off the sounder.
Is there a command i don,t know about ?
I have used a magic scene "if alarm is disabled then turn off sounder" it does nothing
second issue is the button when configured as a panic button  you have to hold it down for a second rather than just push it, if you just push it it says transfer successful just does not trigger the alarm
i would have thought as a panic button just a push would do ?
Guest spazpeker
    WOW 40 views no replies,
    i was hoping i had just missed the obvious command to detect the alarm being disabled and then turn off the sounder !!!!
    Hi @spazpeker,
    I have one scene that is triggered when alarm is breached and that scene sends me popup notification with two buttons. "Cancel" button is to leave alarm and sounder On while "Disarm" button starts another scene which disarms alarm and stops sounders. Both scenes have checked option "Do not allow alarm to stop scene while alarm is running". Last time when checked working was on HC2 with 4.120.
    I have two Fibaro buttons of which one stop working and is now collecting dust in drawer for failed devices. The other one is used to reset coffee machine VD and still working ok. I didn't test them as panic button but the first one that is collecting dust was also showing message "Transfer OK" when pushed (long or short or multiple) but never ever triggered any scenes any more after few months. Since I couldn't remove it properly from z-wave network I used force and then try to reset it many times according to the manuals, but never manage to include it to the HC2 again. What a shame! :-(
