Matt654 0
Hello, not sure if it should be here or other topics..
I need some help with creating a virtual device for Anthem MRX 720. I am just after basic working out the format, i will create the control after..
I have tried it like below and doesn't work. the amp freezes and wont take any more input by remote or physical on panel.. i have to unplug after i tried fibaro command and the reset.
I am new to virtual device for AVR so i have taken some code from DENON remote
(Device ip 192.168.1.7 and port is 14999) - should i use this port, or port 80?
fibaro:log("Connecting...");
local selfId = fibaro:getSelfId();
local icon = fibaro:get(selfId, "deviceIcon");
fibaro:call(selfId, "setProperty", "currentIcon", icon)
local ip = fibaro:get(selfId, 'IPAddress');
local port = fibaro:get(selfId, 'TCPPort');
tcpSocket = Net.FTcpSocket(ip, port);
tcpSocket:setReadTimeout(2000);
tcpSocket:write("Z1POW1")
fibaro:sleep(1000);
result, err = tcpSocket:read();
tcpSocket:disconnect();
if (err == 0) then
fibaro:log("transfer OK");
fibaro:debug("transfer OK");
else
fibaro:log("transfer failed");
fibaro:debug("transfer failed");
