Ros 22
Hi guys,
I have an electric water switch connected to Fibaro Switch 2. On and Off are two different switches, so I need to create a VD with On and Off buttons which would fire respective switches.
I have created a code for the 'On' button. When pressed, this button needs to check the globalvariable LeakStatus and send the 'turnon' command to the switch only if there is no leak. The code is below.
local Leak = fibaro:getGlobalValue("LeakStatus")
If ( Leak == "NoLeak" )
then
fibaro:call(29,'turnOn');
fibaro:setGlobal("WaterTap2Status","Open");
fibaro:debug ('Water Tap 2 is Open')
else
fibaro:debug ('Cannot turn on, because there is a leak detected')
When debugging, I get
[ERROR] 19:26:13: line getGlobalValue("LeakStatus")..."]:4
What am I doing wrong?
Edited by Ros1 answer to this question
