Fibaro with Google home
Hello guys! I want to integrate HC2 with Google home voice. How should I configure, is it possible compatibility?
5 answers to this question
" to "
Temat został przeniesiony z "
" do "
I use HA Bridge for this (
Not optimal, but it works. (Simulates Philips Hue). Currently, you have to add all devices/scenes you want manually.
(And you need a server or raspberry pi or similar to run it on)
I am having hard time pairing the Google home to the HA Bridge. DId you run into any issue?
As long as you run on port 80 it should be fine. It seems to be issues with connecting on other ports.
    Infelizmente eu ainda não consegui configurar o Fibaro no Google Home.
    Você pode usar o Central SmartTrings / Samsung para o Google Home para conversar com o Fibaro?
    Edited by Savio
