Playing around with a new scene that will secure my house when house is empty. Will work with @Sankotronic VD HOME STATUS (but i cannot find the link anymore) and also triggers other variables.
More info will come :D
Edited by jompa68
Hi @jompa68,
Great to see that you are busy! Home Status VD comes with Main scene FTBE and you can find it here:
but I must mention that new version is on the way. I almost publish it but then I found problem with global variables being destroyed if contain table values so I have to change code to avoid problems for users that will use that solution. I want it bullet proof! :-)
