cjard 1
I've 8 halogens in one room, running on a dimmer 1. After contact with a high speed football (oops) the RCD for the circuit* tripped. After resetting the RCD the lights came back on, apart from the bulb that was struck.. I've since noted though, that they won't turn off! Switch continuity is good. Using a jumper wire to briefly connect Sx and S1 had no effect. Using the web app/mobile app to control the dimmer has no effect; the settings look like they work in that it accepts a change to the slider for brightness, and the dimmer gives readings/can be queried in the admin pages and responds to commands to alter parameters, but never varies its output to the bulbs - it's locked to "always on max brightness"
is the dimmer ruined?
Edited by cjard3 answers to this question
