[SUBMITTED]permanent warning notifications...
Hay FIBARO
can you merge similar permanent warning notifications...
I'm not blind, thank you!
Same here:
Three notifications for only one device that is actually working perfectly fine! I wonder how many notifications I will have after including second device?
Yes FIbaro, please... This is not only obsolete, but quite annoying.
Did you check that there actually is a forum for suggestions? ;)
" to "
Temat został przeniesiony z "
" do "
    so, It's not a bug, it's a feature!
    OK!
    @10der, I do not see how this prevents you from using any part of our system.
    Additionally, you asked "if we can merge the notifications" - so you suggest something. It's an idea so I moved the thread to Crowd's Ideas.
    What is incomprehensible for you?
    sorry. I think it's a bug - "FIBARO UI show duplicates of similar messages"
    But if you think it's FAD - OK with me!
    przepraszam.
    No, it is not a bug. A bug is an error or flaw of a system that causes the system to malfunction.
    Moreover, these notifications come at a different time so they are completely separate notifications but they refer to the same device.
    I submitted your suggestion to our team ;)
    Thank you @T.Konopka for submitting this suggestion.
