 I will bay a RGBW controller and i wil need some sensors.
I have searched for a couple of days for some sensors, i found more people in diverend forums and they are looking too. I was searching if there was a list of working sensors but i don't find this.
Now was i thinking to make a list of different working sensors but i need some help.
I have make a start but if anyone have good working sensors and add this to the list so that anyone can look in this list to find sensor the can yuse.
I hope that you will add the info.
6 answers to this question
Hoi Reinhold,
Bought my temp sensor here
grtz
Sjekke
DS18B20 is not compatible with the Fibaro RGBW module. The DS18B20 is digital, the RGBW is analog. I cannot recommend a temperature sensor that outputs analog data, but undoubtedly someone reading this will have a link. But I still wouldn't use the RGBW for this application. The analog signal is called "0 - 10 V". I have a working 0 - 10 V light sensor, but it needed extra buffering, so not all analog sensors are compatible out of the box. At the moment , The DS18B20 can be used with the "Universal Binary Sensor". Newer modules, like newest Fibaro D/W sensor and Motion sensor have temp sensor bult in.
Edited by petergebruers
Add link to light sensor discussion
Also, note that an RGBW module divides the 0-10V signal in 100 steps.
This means that a sensor for -20 to +80 degrees only shows the temperature in increments of 1 degree, no decimals.
    This is way i want to make al list. There are manny diverend sensors.
    Who use sensors in combination with the RGBW and with sensor are you using?
    As I wrote above, it will not be meaningful to use an RGBW module for sensors.
    According to your list, a wind guage would only report wind speed in step of 0.35 m/s.
    For example, 0.35, 0.7, 1.05, 1.4 m/s, etc.
    Your light meter should report in step of 600, 1200, 1800, 2400 Lux etc.
    The only sensor that makes sense is a moisture sensor 0-100%.
    What do you suggest?
