ID 0: Application Busy; try again later
I just noticed these messages on my HC2.  I remember seeing them mentioned sometime ago on the forum but can not find it.  Anyone has any idea what the error represents?
Thank you
4 answers to this question
" to "
Temat został przeniesiony z "
" do "
Guest chaicka
Not sure if it is of any help...something similar but different error message ->
There is a response from Fibaro staff about it.
Using similar approach, your error message may means the device responded to HC2 that it is busy, hence not receiving any command sent to it.
Edited by chaicka
ID 0 - Z-Wave network
ID 1 - Controller/Gateway
ID 1+n - other devices
Application rejected request - a device, including a gateway, rejected a request as it was performing a task or does not recognize the command and could not process the request in the very moment. Sending the request again after "some time" should not have the same result.
Application busy - a device, including gateway and Z-wave, is simply busy performing tasks.
    ok thank you. so nothing to worry about :)
