How to handle nil value from http request
I am setting up some controls for my chromecast audios with a webserver on a raspberry Pi, I am fetching the values like volume and whats playing, but when there's nothing playing on the chromecast I get a nil value and the scene stops, how can I handle these nil values?
could I use something like if ~ = nil ?
local http = net. HTTPClient ()
http : request ( "http://xxx/getDeviceStatus?address=xxx",  {
    options =  {
        method =  "PUT",
    success = function(status)
       response = status.data
    svar = json.decode(response)
      --printer verdier
      print ("Volum: "..svar.status.volume.level);
      print ("Muted: "..tostring(svar.status.volume.muted));
      print ("Spiller fra: "..tostring(svar.status.applications[1].displayName));
      print ("Media: "..tostring(svar.status.applications[1].statusText));
      print ("sessioId: "..tostring(svar.status.applications[1].sessionId));
     fibaro:setGlobal('volumbad',svar.status.volume.level);
     fibaro:setGlobal('spillerbad',tostring(svar.status.applications[1].displayName));
     fibaro:setGlobal('idbad',svar.status.applications[1].sessionId);
Debug:
4 answers to this question
Yes, I think so.
if (svar.status ~=nil) then ... end
@mortesan
You could check just after the response read for a part of the json that you would expect to be there
Here is a an example I use..
for the else you could use
return - if its part of a function  or fibaro:abort() - which will stop that iteration of the main loop/button..
    Thank you for some good advise, got it working with if == nil then ..  else ...
    if svar.status.applications == nil then
            print ("Volum bad: "..svar.status.volume.level);
            print ("Muted bad: "..tostring(svar.status.volume.muted));
            fibaro:setGlobal('spillerbad',"Nothing is playing");
            else
          end;
    Edited by mortesan
