I have edited a scene for key fob and it was on Setup Mode. but it doesn't work on mine. thanks
%% properties
443 sceneActivation
%% globals
local ButtonPressed = fibaro:getValue(443, "sceneActivation");
if ( tonumber(ButtonPressed) == 1) then
fibaro:call(81, "setMode", "2")
fibaro:debug("Keyfob button 1 pressed - Turn On AC")
elseif ( tonumber(ButtonPressed) == 2) then
fibaro:call(81, "setMode", "0")
fibaro:debug("Keyfob button 2 pressed - Turn Off AC")
elseif ( tonumber(ButtonPressed) == 3) then
fibaro:call(41, "turnOn")
fibaro:call(53, "turnOn")
fibaro:debug("Keyfob button 3 pressed - Turn On All Lights")
elseif ( tonumber(ButtonPressed) == 4) then
fibaro:call(41, "turnOff")
fibaro:call(53, "turnOff")
fibaro:debug("Keyfob button 4 pressed - Turn OFF")
elseif ( tonumber(ButtonPressed) == 5) then
fibaro:call(31, "turnOn");
fibaro:debug("Keyfob button 5 pressed - Turn off Alarm")
elseif ( tonumber(ButtonPressed) == 6) then
fibaro:call(31, "turnOff");
fibaro:debug("Keyfob button 6 pressed - Turno On Alarm")
elseif ( tonumber(ButtonPressed) == 7) then
fibaro:call(159, "turnOn")
fibaro:debug("Keyfob button 7 pressed - Turn on ceiling")
elseif ( tonumber(ButtonPressed) == 8) then
fibaro:call(159, "turnOff");
  fibaro:debug("Keyfob button 8 pressed - turn off Ceiling")
else
fibaro:debug("No response")
Edited by Infinity
Hi @Infinity,
i'm using this scene for Keyfob:
so for triggering i use: "646 CentralSceneEvent" don't forget the %%events in the header
then i check the trigger with "fibaro:getSourceTrigger()"
and then i call the appropriate scene by scene number, not using directly "fibaro:call" statement....
Hope this will help a bit.
Edited by Bodyart
