Hass support Fibaro?
Hello everyone
Can Hass support Fibaro?
How does this need to configure 'Configuration.yaml'
2, Hass access FIbaro, which needs to install HOmebridge? (Homebridge-fc2)
Edited by Gee
If you want to have a switch in Home Assistant that turns on/off z-wave switches in Fibaro Home Center 2 then you could define this in configuration.yaml
switch:
 - platform: command_line
    switches:
      <switch01>: # This is a unique id for switch in home assistant, that can be used in automations etc referenced as switch.switch01     switch.switch02 etc if you have more
        friendly_name: 'Fibaro Wallplug On/Off' # Direct access HC2
        command_on : 'curl -u <userid>:<userpassword> -X POST "http://<HC2 ip address>:80/api/devices/<deviceid>/action/turnOn"'
        command_off : 'curl -u <userid>:<userpassword> -X POST "http://<HC2 ip address>:80/api/devices/<deviceid>/action/turnOff"'
It works BUT it has a few inconveniences I have not found out a solution for yet:
- delay of about one minute. If you issue the URL directly from Chrome the on/off is instant, but not using curl
- the icons in Home Assistant does not show that the Home Cneter lights are on. That is even after you pressed the button and the lights are on, it does not show.
It works ok for me in automations where I want to turn on/off according to sun or at specific times where immediate action is not vital. Still irritating though.
Please note that you need to change <> and text between to valid information for your installation
    wow,Understand that if I have a lot of Fibaro device, is it necessary to write a lot of corresponding Http request URL
