Anyone come across this device?
Quote
It is a Z-Wave™ enabled device (interoperable, two-way RF mesh networking technology) and is fully compatible with any Z-Wave™ enabled network and it’s security framework. Every mains powered Z-Wave™ enabled device acts as a signal repeater and multiple devices result in more possible transmission routes which helps eliminate “RF dead-spots”.
Z-Wave™ enabled device displaying the Z-Wave™ logo can also be used with it regardless of the manufacturer, and ours can also be used in other manufacturer’s Z-Wave™ enabled networks.
Z-WAVE2RTS interface receives Z-Wave signals and translates them into RTS commands for Somfy’s RTS motor. The Z-Wave2RTS interface supports mulit-channel Command Class for up to 8 devices corresponding to 8 individual or groups of Somfy motorized products. The Z-Wave2RTS requires 12-24Vdc power supply by power adaptor or 5Vdc via micro-USB adaptor.
Very interesting....
nice....
Guys from Somfy told my customer (Fibaro dealer), that this device if for Asia market only and they are unable to obtain one.
Absolutely interesting. But I see: Window Covering - No Position/Endpoint
And that's a problem of the Somfy and Velux products I have with their I/O system.
When I control my rooftop windows I can't see their current state / position.
That's a big pro at Fibaro!
