Hi
Can anyone help me with a code to turn on lights when motion is trigger, then start a countdown to turn off the lights?
I also need them to start countinig from start if any new motion is detected.
Br
Kim
6 answers to this question
" to "
Temat został przeniesiony z "
" do "
hi @kimstoroy,
what modules are you using?
I used a Fibaro motion sensor and a fibaro double relay switch.
The fibaro double relay switch has a parameter for automatic off. There you could set the timeout to turn the light off after a specified time.
You even don't need to code.
Just create a magic scene:
- when motion sensor is armed and tripped
- Turn on the light
The ligth will then automatically switch off after the timeout.
If you then want to go further you can convert the magic scene to lua and have a working basis already.
BR - Kro
    Hi, am using 2 Fibaro dimmer 2 and 1 relay switch.
    The motions ensor is connected to a universal sensor, so it need to be some kind of LUA code i think.
    Br
    Kim
    most easy without scenes or coding is:
    use a fibaro pir,
    set off to 30 seconds (or the time you want to shut the light off)
    associate the relay switch to the pir
    Yes, but the challenge is that i only want them to be activated when it`s dark outside, I have a Global value for that
    hi @kimstoroy,
    how about
     or
    tutorial.
    shouldn't really matter if using UBS or other motion sensor.
    Instead of light sensor you can use your global variable.
    When finished you can still convert it to LUA.
    The advantage will be, you'll have a working example already.
    BR
    Edited by kroeatschge
