Automatic Curtain behind door opening and closing - Help please
Hello, I have a roller shutter 2, a ranch slider, aeon door sensor gen 5 and a electric curtain.
At the moment when the door is open the curtain behind door opens and sets a global var to automatic
My two scenes coded are as follows:
If door is breached and the curtain is closed then open the curtain and set global var to automatic
Then a second scene.
If global var is automatic (ie the curtain was opened by the scene above) and the curtain is open still and the door is now closed
then change global var to manual and close the curtain
To me it seems right, however the curtain no matter how it's opened is always closing automatically. Does the above look right or am I missing something.
Thank you
try to do the same with block scene, if this works change it to lua and look which code is different
I am a little bit confused what exactly you're trying to achieve, but looking on your code it works correctly  i.e  door closed -> close the curtain.
What do you mean by "the curtain no matter how it's opened is always closing automatically"?
Please describe the case when the curtain closes unexpectedly (not according to your plan ).
In addition could you share the entire scene's code, including triggers.
One more question - as I understand  from your explanation the curtain should be closed or opened according to the door state, so  why you need two scenes and global variable. It could be done in one scene/code w/o variable, but may be i didn't understand correctly,  please explain what exactly you need?
Edited by cag014
