Alarm pincode keyboard
Can i do a scene or vd to switch of alarm and it will bring up the pin code keyboard before it disarm the sensor?
You can use pin code for a scene if this is what you are asking?  Just check the "protect by pin" and the keyboard will pop up if you try to manually start the scene. You cant use pin protectet scene as widget.
    So simple :oops:
    Thanks @mortesan
