LUA Scene Help PLEASEEE
Hey Guys,
I've got a scene that turns my garage lights on when the garage door opens although i want to do a check that in the event the lights are already on to not turn them off after two minutes.
Below is the code i've got so far but i think there's an issue with the IF statements and need someones keen eye to quickly find where my fault is. I believe i havent correctly closed of the second if statement.
Its currently turning the lights on all the time instead of only at night
%% properties
99 state
9 value
%% weather
%% events
%% globals
if
(fibaro:getValue(99, "state")== "Open" and  tonumber(fibaro:getGlobalValue("NightTimev2")) == tonumber("1") )
then
    if (
 ( tonumber(fibaro:getValue(9, "value")) > 0 ))
    then
    else
    fibaro:call(9, "turnOn");
      fibaro:sleep(120000)
      fibaro:call(9, "turnOff")
removed the "9 value" at the top, the trigger should be only the "99 state"
added instance count
removed the else
added the 2 if's together
changed the tonumer(1) to 1
    Thanks mate.. perfect.. upon reading you solution i immediately thought "doh thats how i should of done it originally" haha u guys are awesome
    " to "
    Temat został przeniesiony z "
    " do "
